219-263-0073
RustSeal Used To Restore Frame
Frame Coater Kit: https://www.kbs-coatings.com/frame-coater-kit.html
The KBS Frame Coater Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 50 square foot area.
KBS Coatings’ 3-STEP SYSTEM of RustSeal (a rust preventive coatings), KBS Klean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today.
RustSeal chemically bonds to bare metal to form a permanent, moisture resistant finish that is flexible yet won’t crack, chip, or peel. Because RustSeal is moisture-cured, this superior coating is made even stronger by continued exposure to moisture.
RustSeal is also highly resistant to some of the most aggressive chemicals such as acids, alkalis, salts, abrasive materials, fertilizers, coal dusts, solvents, oils, and other refined petroleum products.
