219-263-0073
Gas Tank Sealer Kits
Used by professionals worldwide, Gold Standard Fuel Tank Sealer is a superior, one part, ready-to-use fuel tank sealer that is specifically formulated to stop rust and corrosion. When used in combination with AquaKlean and RustBlast, it will form a super-tough, fuel and alcohol impervious coating, while simultaneously sealing small pinholes and weld seams. It’s been rated as the industry’s NEW Gold Standard in gas tank sealers.
Gold Standard Tank Sealer may be used on steel, aluminum, and fiberglass tanks.
Applications: Gas Tanks, Diesel Tanks, Oil Tanks, Utility Tanks, Motorcycle Tanks, 4-Wheeler Tanks, Tractor Tanks, Generator Tanks and many others…
Available in Convenient Kits for most sizes of tanks!
+CHECK OUT THE KBS TANK SEALING KITS
