I noticed a very strong gasoline smell coming from my garage one day,I Started looking around at all my toys and noticed my motorcycle gas tank was leaking.
I started looking online for a new one(Ebay)first,All I could find was used ones that where dented and beat up for $300.00 to $500.00 range,As my bike is a 1989 they are a rare find.
I then went to some online motorcycle forums to see what other people where doing to fix their tanks and came across the KBS Coatings name as being one of the best repair options out there. There is a few other companys offering tank sealer kits but KBS was rated as a much better product to use. So I ordered the 3 part system kit and was pretty easy to do. The Aquaklean and Rustblast formulas work very well. It started off with a pin hole leak and ended up with roughly 10 more when I was done the 1st two processes,I ended up ordering their NuMetal Epoxy to be sure the holes where filled before sealing was put in. All said and done about 10%cost 0f a new tank,It is a real good deal and very easy process to do.
-drywaller
You can find complete instructions for the Gold Standard Gas Tank Sealer here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html
You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with Tank Sealer here: http://www.kbs-coatings.com/fix-it-guide-tank-sealer.html
You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html
You can also find Tank Sealer Flow Charts here: http://www.kbs-coatings.com/Flow-Chart–Tank-Sealer_ep_88-1.html
